stormydart
Looking at Aeromotive regulators not sure which. It will be a blow thru 360 magnum. Which one do you guys recommend. Thanks
Yes return after the pump. Car has a -10 going to the front. Was told I have to block the return that is on the pump and run it from the regulator.are you doing a return line? putting it before or after the pump?
ThanksI have a 13301 but they have newer models.
sorry, i meant after the carbYes return after the pump. Car has a -10 going to the front. Was told I have to block the return that is on the pump and run it from the regulator.
sorry, i meant after the carb. Usually do before the carb
