which intake???
URDUST73
time for the COLD wrench!
Dayton OH
Building the top end on my 440 Duster track car... So six pack or 850 double pumper? Any other opinions? Will be running Performer rpm heads (so far).
What rear gear, cam, compresion ratio and stall converter as well as time sought?
You said track car. As fast as you can go right?
A blind guess would be a Edel. Victor.
For a track-only car it is really hard to beat the venerable Holley double-pumper because of their nearly endless tuning possibilities and parts availability.
Either a Mopar M-1 single plane or a Holley street dominator 300-14. The street dominator is about an inch lower so you'll have better hood clearance if you don't put a scoop on it. Personally, if its a track car, put that scoop on it, get the M-1 and make a pan to seal it to the hood and use that 850 holley.
Yep..go with the Holley......I like my M1 on my small block so I'd say go with the M1 or a Victor both about equal IMO. 6-packs look sweet but for all out performance you can't beat a Holley with a single plane intake. The 6-pack dual plane will be very restrictive vs the Single.
