Which motor mounts for a 318 Magnum
hemidart1
Moncton, NB
I'm putting a 318 magnum in a '66 Dart that was a slant 6. My question is does this motor use the same mounts as a 340/360 or do I need to find ones that adapt to a 273/318 block?
thanks
Al
sublimeswinger said:
you need the conversion kit from schumacker i belive.
Early a-bodies have the same k-member for the /6 and V8. You just need the 273 mounts and insulators, but hemidart brings up a good question, does he use the 273 mounts or are the magnum 318's the same as the 360 as far as the block mount is?
Chuck
