Which throttle bracket?
project74
Windsor, Ontario
I need some advice on which throttle bracket I need to run an AVS on top of an LD4B. Stock 4 brl, tall, adjustable? Needs to work with a cable kickdown setup as well. Manifold is a little taller than stock but I don't think it would qualify as a high rise either. Anyone else running this particular manifold/carb combo with the cable kickdown?
Return spring bracket is kind of a mystery too. There's no "hole" in the manifold to cradle the small hook end of the stock return bracket. :-s
