Who can I.D this balancer
mbaird
mbaird
Boise, Id
Yes... but to what ?
It is a Pioneer that was sent to me instead of the SFI LA one I ordered. It was in a LA box with correct LA PN .... The seller just refunded my money and said to keep it. I figured I would sell it if I can figure out what it goes to...
not a clue
but there are numbers on the rubber insert
id imagine who ever send it to you should be able to run the numbers and tell you what it is
I googled all the numbers with no result. Also showed it to a few machine shops...none had ever seen one with a pilot shaft.
that pilot shaft may be a spacer
still no clue
does the place you bought it from have an online catalogue?
it may be in there
That's a balancer for a bunch of different late model BMW's with a specific options package. OE BMW number is 11 23 7 561 312 . Dayco is the OEM and the aftermarket part number is PB1745N. That balancer is worth 3-500 bucks. Lucky you.
Your the man ! How did you figure it out ?
I been working on cars since I was 5yo and I'm the primary mechanic at me and my dad's shop. We work on literally everything. Just looking at that part tells me that it's from a later 6 cyl BMW and I noticed it has 2 belt drives on it and the only ones that have that are the ones with 4 zone climate iirc. I think maybe I been in the business too long. Haha
