I do admire those Stock Eliminator guys, they do so much with so little! My combo has ran a best of 11.67 @ 113MPH last weekend. With the 125 shot, it ran a 10.98 @ 121 MPH! My car is a street car, full interior, all steel. Car wt is 3360 with driver. 1985 360 block bored .020, std. 360 crank, 340 rods, KB107 pistons @ zero deck, balanced,(I also have one of the best machinist around) Hughes solid camshaft #HTL5256AS - 572/579 lift 252/256 @ 50, springs, timing set, out of the box Eldebrocks, Crane Ductile 1.5 rockers & pushrods, Holley Strip Dominator, 750 CFM Holley D/P, Mopar Tach drive Dist. with timing set at 32 degrees, MSD 6AL, Hooker 1 3/4 headers, 3" exhaust w/bal tube, Dynomax ultraflows, Dynamic 9 1/2 convertor, 904 TF, 2.74 Low gear set, Turbo Action man. valve body, 3.91 Suregrip 8 3/4 rear, pinion angled 4 degrees downward, long rr shocks, stock 340 leaf springs, 318 t-bars up frt., 90/10 frt shocks, bolt in frame connectors, P255-60R-15 M/T Drag Radials. 60fts with the radials are 1.61 to 1.67, however last weekend I used a set of M/T ET Drag Slicks -9 X 28. 60ft w/slicks 1.59 to 1.60, on the bottle it was 1.51! My winter plans are 6 cyl. bars, complete Cal-Tracs set up out back, 4.30 gears, & a new set of 9 X 28 ET Drag Slicks.
