who is using their facctory k frame?
rapidtransitric
LX/LC platform a body swap pioneer
richmond illinois
i will be using the original k member and considering making my own mounting plates. what is the height/distance of the crank bolt to the top of the k frame
thanks
Are you thinking of a motor plate or a motor mount? Because once you stuff the motor in there you will find out really fast that there is no room to fab a motor mount.
Let me know what measurements your wanting and nexttime I am near my car (nov 12) I'll take measurements for you. I have the factory k member and RTI mounts
hey thanks i appreciate that. i don't have an oil pan yet. so i need a measurement lets say from the block to pan mounting face to the k frame. this way i can set her in at the right height to eliminate any clearance issues later
thanks
i found it
Gen 3 Hemi Crate Engines (5.7L, 6.1L, 6.4L) / 62-65 B-body applications with spool mounts: From the center of the crankshaft to the top of the K-frame, the correct distance is 6-3/8" (to be determined). The engine is also offset towards the passenger-side. Measure from the center of the crankshaft to each frame rail, the difference should be 2-1/2" (to be determined).
63-66 "A"-body applications: From the center of the crankshaft to the top of the K-frame, the correct distance is 4-3/4”. The engine is also offset 5/8" towards the passenger-side. Measure from the center of the crankshaft to each frame rail, the difference should be 1-1/4”.
62-65 "B"-body applications: From the center of the crankshaft to the top of the K-frame, the correct distance is 5-1/4”. The engine is also offset towards the passenger-side. Measure from the center of the crankshaft to each frame rail. The difference should be 3”.
67-76 "A"-body / 66-74 "B"-body / 70-74 "E"-body applications: From the center of the crankshaft to the top of the K-frame, the correct distance is 5-1/4”. The engine is also offset towards the passenger-side. Measure from the center of the crankshaft to each frame rail. The difference should be 2-1/2”.
65-73 "C"-body applications: From the center of the crankshaft to the top of the K-frame, the correct distance is 5-1/4”. The engine is also offset towards the passenger-side. Measure from the center of the crankshaft to each frame rail. The difference should be 3-1/2”.
gines (5.7L, 6.1L, 6.4L) / 67-76 A-body / 66-74 B-body / 70-74 E-body applications: From the center of the crankshaft to the top of the K-frame, the correct distance is 5-5/8” for A-bodies (5-7/8” with spool mounts) and 5-3/8” for B&E-bodies (6” with spool mounts). The engine is also offset towards the passenger-side. Measure from the center of the crankshaft to each frame rail, the difference should be 3-1/4” for A-bodies (2-3/8” with spool mounts) and 2-1/2” for B&E-bodies
Sweet deal. Glad you found it. Did you get that from tti? Now that you posted that I remember seeing something similar on Thier site.
the measurements are to make the headers fit in the engine room and with the torsion bars. I did use them but ended up with mounting the headers and cut the mounts in its pieces, make everything fit and welded them together again. For me there was no other option. No idea why. I tried more then 2 weeks on any other way than cutting. But it works and I have now 2000miles (a lot fast lane Autobahn ;-) ) w/o any probs or vibrations.
thanks buschi
