Who makes a great "high heat" paint?
MoparMuscleGuy
Still plays with cars.
Cocoa, Fl
Hello, I'm looking for a great high heat paint for my stock exhaust manifolds. I've got a couple ideas but would like to hear what you have had great luck with. Thanks
I used the 1200 deg flat black on my manifolds
http://search.eastwood.com/search?asug=&w=high+temp&p=Q&ts=custom&x=10&y=10
Does Eastwood sell their product in stores locally or internet only? I've only found it on the net.
i use BBQ grill paint...seriously when was the last time you ever saw a bbq that was not black.
stuff works great and is cheap.
I used VHT on my cast Oldsmobile intake manifold when I removed the carb for a rebuild (removed the intake too just because it looked dirty (just an excuse to paint it). Following the directions...I used the VHT primer and then applied the VHT top coat (gold). It roasted right off the heat cross over in about 30 seconds. I was not happy. I think we are going to use the POR15 Chrysler Blue on my sons 360 Duster project. I've heard good things about it.
