Dodge74
Selling from Riverside, CA
Hi Everyone,
I have a whole bunch of parts for sale. The only reason I am selling is because I need to move my family to Florida because my wife needs a kidney transplant. The wait in California is 8 to 10 years plus. Florida takes 2-5 years. My wife is currently hovering between CKD stage IV and stage V http://www.davita.com/kidney-disease...disease/e/4751, if you are curious. Anyway, the following items are for sale:
Brand new volt meter-$10
Tachometer-$30
Sending Unit 5/16"-$20
TTI Header gaskets (new)-$10
Edelbrock throttle lever kit#1481-$10
Ignition box NIB-$25
Carb book-$20
Torque converter balancing kit-$25
Stock torque converter 904-$20
8-blade water pump-$20
Timing Cover w/seal-$20
Aluminum Fan blade w/fan clutch from Dart Sport 360-$30
7-blade fan blades w/o clutch-$15
7-blade fan blade for fan clutch-$15
Spring height tool-$10
Automatic column shift lever-$10
Comp Cam degree kit-$60
Pair of Thrush mufflers (2 1/2" intake and outtake)-$25
2 flex plates-$10 each
Alternator-$15
Carb spacer-$10
Alternator bracket V8-$10
Transmission dipstick and tube-$15
Slant 6 power steering brackets-$15
Manual steering box '73-'76 (comes w/steering shaft rebuild kit)-$65
Torsion bar removal tool-$25
8 3/4 3rd member casting 489 w/open gears-$60
Another 489 casting w/no gears (empty)-$40
Recore-ready to go Slant 6 radiator w/shroud-$45
Bumper shocks w/brace off of a '74 Dart-$$Make Offer$$
1 set of Edelbrock guide plates and set of studs-$20
2 sets of cylinder heads 360 smog off of crate engines; ready for clean up and installation (no valve job needed)-$25 for the set.
In addition to these items, I have a complete set-up for Magnum head swap to LA block
-Stud kit
-NIB push rods
-16 Comp Cam roller rocker arms 1.6
-NIB Hughes springs, retainers, locks
-Set of production Magnum heads; ported and polished. Have already been crack tested
-Valves are also production w/valve job
I am selling this conversion kit for $200, ready to go.
Customer pays for shipping on all items. Sorry, no PayPal, money orders only.
Pics coming shortly
Thanks in Advance,
................................PETE.............. .....
Hi Everyone,
Tachometer-$30
Carb book-$20
Alternator-$15
Carb spacer-$10
-Stud kit
-NIB push rods
Pics coming shortly
Thanks in Advance,
