WHY ............does anybody know the answer
trudysduster
Corinth, Ky.
Ok, I am into a total rebuild on a 1966 Valiant. The engine is a slant 6. I bought some main bearings for it. STD. I bought Michigan brand because I have used them before no problem. The last /6 I used these bearings and that engine runs fine. Didnt pay any attention to this. This engine, I opened up the box and started to put the thrust bearing in and it wouldnt fit. Found out that they slipped a cast crank bearing in the box. so I started looking at the rest of the boxes. The box says : consists of 1 pair 7376T, 1 pair of 7377T and 2 pair of 7378 T. The 7377 T is the thrust bearing. so, why do they have 2 different numbers for the other 3 journals. Arent the other 3 journals the same. I checked the bearings and there is no difference in them. they all fit good and look the same. But I am stumped as to why there are 2 pairs with 1 number and 1 pair with a different number. I have checked other sets of main bearings and they have 1 thrust bearing and 3 sets of regular bearings. So, does anybody know why. I am kinda leary now about using these. What kind of bearings do you use on a forged crank for '66. I need to buy a couple of sets as I have another '66 engine after this one.
Oil hole in different location......comes to mind...........
This might not be an issue but I would have a hard time believing what's inside a bearing box if the original part number has been crossed out. Just sayin'
I just found this on ebay. this I can buy. same Michigan part # 1092T buy look at the parts it says are inside. 1-7377 and 3-7376. That is different from the other box. same seller, same brand
The number 1 main bearing is supposed to have a champher on the upper shell. It is for timing chain lubrication. Except for the champhor the bearing is the same as the #2 and #4
Many if not most of the after market sets do not have the champhor. If I get a set like that I file the champhor on the edge of the bearing shell. I don't know about the aftermarket bearings, but the factory replacement bearing have that marked with a red paint mark.
PS: the factory service manual refers to this.
thanks Charlie
thanks Charlie
The picture isn't mine but I swiped it and modified it to show you where to put the chamfer. Just knock the inside square edge off with a file where the red mark is from the oil groove all the way out to the front of that upper front bearing shell. I don't do that anymore, I just remove the front oil gallery plug behind the camshaft sprocket and drill about a .040" hole in it and put it back. That puts a pressurized stream of oil right on the back of the camshaft sprocket and soaks the timing set. Either way will work fine.
Perfect picture of what to do. Thanks RRR
