73dds
Member
Thanks
What wheels are those?I have 205/60r15 up front in a 15x7 with 4in BS kinda wish I went with more bs but it'll work. And a 225/70r15 in the rear on the same wheel.
The wheels I was looking at have a 3.75" back spacing. Which one would work for that?The 215/60 is about right, a 215/65 would be even better. You can also easily fit 225/60 all around. One thing to be aware of is that you need to make sure that the wheels you get have 4.25" to 4.50" backspacing with the 7" wheels.
Ok wrong link I guess. Would a 15x8 all around with a 4.50" back spacing work better?No idea. But you will be very limited. You'll be lucky to get a 205 tire on it without rubbing on the fender.
By the way, the link takes me to an 18x8 wheel with 4.5" backspacing.
Ok. Nice car by the way! Do you think my 15x7 wheels with a 3.75" back spacing would fit with either a 215/60r15 or a 205/65r15 tire?
I would do that but the wheel only comes in 3.75" BS.You'll be really close to the fender with the 205/60 and will hit with a 215/60. I would stay will at least a 4in BS on a 7in wheel. Be better with a 4.25 or 4.5 inch wheel honestly. The 225/60 all the way around on a 15x7 with a 4.25 BS looks really good.
The answer is, find another wheel. One of the big advantages of having a 4.50" bolt pattern is that there are hundreds of different wheels available. 15x7 with 4.00"-4.50" backspacing is not hard to find.I would do that but the wheel only comes in 3.75" BS.
Just to clarify, do you have 5 bolt 4" bolt circle or 5 bolt 4 1/2" bolt circle? I see the #u107 mags you mentioned above don't come in small bolt pattern. Just making sure.Thank you guys for the help! I really appreciate it! The wheels I'm looking at are U.S. Mags U107 with a 3.75" back spacing. What tire would that work best on?
Yes I have a 5x4.50 bolt patternJust to clarify, do you have 5 bolt 4" bolt circle or 5 bolt 4 1/2" bolt circle? I see the #u107 mags you mentioned above don't come in small bolt pattern. Just making sure.
Thanks I think I'll go with these. Do you think they would look good on my car? (Picture is on the first post)141 Legend 5 - Vision Wheel
15x7 with 4.25 BS black spokes with machined lip.
Also try summits website, has a real easy way to narrow down to what you like.
Yeah I was thinking about running a 225/60r15 with it. And I'm not really a fan of the wheels that are on it now either. By the way, I really like your Challenger. Looks good!They'll look good! Of course I'm not a fan of the wheels that are on there now at all, they look like they should be on an early 90's Ford Ranger . And I may be biased. These are legend 5's on my Challenger, although these are 17x9's.
Summit carries them
https://www.summitracing.com/parts/vsw-141h5765gm6/overview
And with a 15x7" and 4.25" of backspace you should be able to run 225/60/15's if you want.
