440outlawdart
this is it with 31x13 was at the edge of quarter panel and was mini tubbed,,the 70-71 you can get a bigger tire,not the early pre 70Cool, thanks for your reply. I will go 13×31
Thank you, that is f'n bad ***, I'll be doing my wheel openings just as you have.this is it with 31x13 was at the edge of quarter panel and was mini tubbed,,the 70-71 you can get a bigger tire,not the early pre 70
car came from vegasDid that car one time belong to Russel Law...I believe his name was....
test fit before cutting anythingThank you, that is f'n bad ***, I'll be doing my wheel openings just as you have.
Hey, I'm curious if you're running hooker fenderwell headers & if so what size front tire works for you ?test fit before cutting anything
car came from vegas
That sounds nice, got a picture?I had 28 11.50 15 ET Streets on 15x9 Center Lines under my 65 Valiant. No mini tubs. Leaf springs moves in 1/2" with the MP kit.
