I have a 68 dart with a 170 that is worn, I have the oppertunity to purchase a 67 Plymouth fury 225, wondering if the 225 will bolt up to my transmission?????????
Your 68 Dart torque converter most likely has the larger hub; the 67 motor most likely has the small register in the crankshaft. All you'd need is the small to large bushing adapter available thru Wildcat, Torqueflite Patty and others
Nope. Just the other way around. The crank adapter will allow using a 68 engine, with a 67 trans.
Just to be clear, I was wanting to put the 67 plymouth fury 225 where my 68 dart 170 used to be. I just don't know if the fury 225 will bolt up to my dart tranny. I don't mind buying an adapter or two.
Did I get it bass ackwards? Dislexic of the brain I guess lol!
why not use the engine AND trans from the Fury?
