74360duster
JEREMY
tomorrow i will finish assembling my new 440 for the dart.it is .30 over.has 13.5.1 forged domed ross pistons,452 heads.flow over 309 at 680 lift.has a bullet .675 lift full roller cam,lifter,rockers,etc.crank is turned .20.steel.
fully balanced,has eagle h-beam rods.aluminum w/p housing,elecric pmp,m1 intake ported matched,have a friend with same combo slight different cam running 10.0s in a fully bodied and interior 70 barracuda.weighs 3400lbs.i am running a striped 74 dart swinger figuring 3000lbs or less.5000 stall convertor.my race shops desktop dyno showed this motor to make 734 hp.so i am figuring upper 600's should be achieved.my question is will my 8.75 rear end with yukon axles hold up to this.i will probably be rnning a 4.30 or 4.56 rear spooled w/29.5x10.5 slicks.
