Will my 833-A Transmission from a 440 GTX 69 fit an early a body with a 225cui slant six? Now it sits in my 68 Dart with a 440. But if i change the bellhousing and change the "cluth kit" will it fit?
It can fit if you measure the bell housing hole and the front yoke diameter to check for size differences.Not all 4 speeds come with the same front yoke seal assembly.If you go to the year one web site and look into the manual tranny ID,you will see the difference,check it out and post back,Mrmopartech
I believe there's more to "fitting" than mating it to the motor. You're going to find that GTX trans is a long tailshaft unit and provides no good way to get the shifter through the hump of an A-body. Check this link for everything you need to know about the A833 in an early A-Body:
