Will p215/60/r14 tire fit a dart steel rim?
It will fit, but it's a little wide and will look pretty bulged-out. The standard rim is 4.5" wide, and 215mm is almost 8.5 inches. It would be a better fit on a 5.5" heavy-duty rim, or a rally wheel. I have 215/70-14 on 14 x 6 rally wheels and that seems to be fine. Most tire manufacturers can provide a list showing the minimum width rim for each tire size.
215mm is the suggested size for a 5.5" wide rim!! The skinnier 4.5" rim will pull in the bead quite a bit!
then I think I'll go with the 205/70, a tire on my parts car is too dry rotted to hold air, so it needs a tire, I got 2 old tires to choose from to put on a parts car so I can move it around!
