moparmatt19
I have a set of 596's fully ported with 2.02 1.60's ok original plan was running a fairly healthy solid cam,but right now I need to run a small hyd lunati cam 230/.480 im using a set of bb springs with installed height of 1.8 and diameter of 1.5. My solid lift dual springs were set at that height so thats why I needed the taller spring for the hyd. And I had a set of bb single with damper setting on the shelf that would work at that height and keep the pressure right... ok to the point.. shew finally right? Ok will the stock stamped rocker arms work and clear the larger springs ? I hope so! The heads are still at the machine shop bc I haven't had a chance to go get them or I could check for my self lol. I got extremely poor in the middle of this project and cant afford the $600+ rocker arms and 3500 stall converter I need for the solid lift cam and i need this engine back in the Dakota so I can drive it. Lol yes I hit a bump and got stranded with only my projects left for vehicles. And this Dakota is the closest one to be street worthy. "Gotta love divorces"! Later down the road when I can buy the rocker arms and converter i can just change the cam and springs out to the solid lift cam. Any comments are welcome ! And thanks!
