Will these work on 69 Cuda?
Tires and Wheels (Mopar Hubcaps Too)
  1. Jason96R
    Jason96R Well-Known Member
    266
    5
    May 22, 2004
    Ohio
    Local Time:
    6:29 PM
  2. ProStocker273
    ProStocker273 MoPar N Jeep
    474
    87
    Mar 20, 2013
    Puyallup wa
    Local Time:
    3:29 PM
    Nope, different bolt patterns.
  3. SGBARRACUDA
    SGBARRACUDA ROY FABO Gold Member
    20,161
    8501
    Dec 7, 2006
    PLANT CITY FL. and PERRY GA.
    Local Time:
    6:29 PM
    Though they might have the correct bolt pattern. As you can see by the picture, these wheels have a lot of back spacing. Which is normal on most late model cars, but may not work on your 69 Barracuda. In other words when you go to put then on, they may hit the leaf springs do to the large amount of back spacing. You would have to physically try them to know if they would work. As far as the age of tires, if you look on the sidewall, you will see DOT, look at the last 4 numbers after that and it will tell the manufacture date. Example, if it said 4113, that means the 41 week of 2013. 0615 would be 6th week of 2015. Stay away from tires over 5 years old.
  4. Jason96R
    266
    5
    May 22, 2004
    Ohio
    Local Time:
    6:29 PM
    Thanks guys. I want matching wheels for my car, front and rear are different, and need new tires anyway. Thought I could get away with those tires at least a year. Current plan is to find another 2 "police wheels" and get best street tires I can get in 15" I love corners if that helps with tire suggestions
