Wanna change valve covers on my 440 with Indy S/R heads with roller rockers, will the mopar polished cast aluminum covers clear the roller rockers? These are baffled.
What brand of roller rocker are you useing? They should clear because I run Indy EZ heads with crane gold 1.6 roller rockers.i am tuning the same valve cover,but mine are the black wrinkle ones.but I would check yours to be sure. They are tall enough,what you have to watch out for is the clearance between the back of the rocker arm and valve cover rail
