Will this cam work well with my radical 383?
Big Block A body Tech
  1. 67charger383
    67charger383 Well-Known Member
    60
    16
    Feb 26, 2020
    Maryland
    Local Time:
    7:23 PM
    Engine specs: 383 bored 30 over, forged rotating assembly with TRW 12-1 dome pistons and 915 heads, Weiand tunnel ram, E85 carb, Msd 6al2, and a Milodon gear drive.
    4.11 gears and a 727
    The cam is a crane 688521
    Solid roller. Here's the cam card:
  2. 67charger383
    60
    16
    Feb 26, 2020
    Maryland
    Local Time:
    7:23 PM
    No response. Wow.
    same thing happened on FBBO
    :poke:
  3. lenky1
    lenky1 Well-Known Member
    566
    211
    Jul 30, 2014
    illinois
    Local Time:
    6:23 PM
    Give it time they engine guys will chime in im sure
  4. Rmoore
    Rmoore Well-Known Member
    417
    249
    Nov 14, 2018
    Gun Barrel City, Texas
    Local Time:
    6:23 PM
    What converter do you have
  5. 67charger383
    60
    16
    Feb 26, 2020
    Maryland
    Local Time:
    7:23 PM
    Don’t have a converter yet
    • Like Like x 1
    • TT5.9mag
      TT5.9mag Two atmospheres are better than one
      558
      541
      May 5, 2016
      So cal
      Local Time:
      4:23 PM
      Do you know your actual compression ratio? Not just what’s on the box the pistons came in. If you had a measured 12:1 and are running e85 and are comfortable selecting a converter to match (+or- 5000 stall) I would not hesitate to use more duration @50. Maybe a little more info about the car. Weight? Intended use? Strip only (if yes more gear also)? Tire size? These are the questions a good cam grinder will ask when you call them. And you should.
      • Like Like x 1
      • TT5.9mag
        558
        541
        May 5, 2016
        So cal
        Local Time:
        4:23 PM
        Will it work? Sure. Will it be “optimal”? Hell its anyone’s guess at this point. I would call a few cam grinders and get a few different suggestions before buying anything.
        • Like Like x 1
        • Rmoore
          417
          249
          Nov 14, 2018
          Local Time:
          6:23 PM
          Make sure you check your PV clearance also !!
        • oldkimmer
          oldkimmer FABO Gold Member FABO Gold Member
          16,457
          4856
          Nov 11, 2006
          Kindersley, Saskatchewan,
          Local Time:
          6:23 PM
          Check the piston to head clearance also. We don’t have a crystal ball either. With no info I would have to say no. It needs gears, 5000 plus stall converter, headers, big carb, single plain intake, traction aids etc. U will get a lot more opinions here. Kim
        • rumblefish360
          rumblefish360 So close, yet so far away FABO Gold Member
          39,012
          10587
          Jun 21, 2005
          New York, on a Island
          Local Time:
          7:23 PM
          With the little info you gave, I’d slam it and run hard.
          I’ll assume you will get the right converter for the car. And everything else... yadda yadda yadda
          246 @.050 isn’t huge but being a solid roller, it’s probably on the fat lobe side.
        • RustyRatRod
          RustyRatRod Bla de blizhibliz de blatde blizi bla bla FABO Gold Member
          64,409
          37360
          Jun 7, 2010
          Georgia
          Local Time:
          7:23 PM
          Did yours get broke, too? You know the story on mine.
        • oldkimmer
          16,457
          4856
          Nov 11, 2006
          Local Time:
          6:23 PM
          No, I didn’t have 1. Kim
        • PRH
          PRH Well-Known Member
          2,604
          3947
          Dec 14, 2018
          So. Burlington, Vt
          Local Time:
          7:23 PM
          Will it “work”?
          Of course.
          How well it works could better be determined by narrowing down exactly what you’re trying to do with it.
          • Agree Agree x 1
