Will this E-brake / Parking Brake fit 67-74 Darts???
ZooKypr
NJ
Will this E-brake / Parking Brake fit 67-74 Darts??? I have it for sale in the Interior parts section and a member is inquiring if it would fit a '68 Dart. Center cable measures approx. 90". It was pulled from a '68 Barracuda. I know the wheelbases differ 3". Any insight fellas?
Pure speculation on my part - the handle should be the same, I suspect the rear cables are the same and if anything is different, it might be the intermediate cable. I base this speculation on the cost of each component - the rear cables would be more expensive if they had to have different ones for each wheelbase. It would be less expensive in manufacturing the intermediate cable. This is pure guessing on my part - the parts books ought to have the answer by part numbers.
Could not find any part #'s to reference, thanks....Anyone else???
I don't know if this will apply to your application. I just checked my 65 Parts book and they show the same cable was used from the parking brake to the equalizer cable and the same cables used for the rear . There is a different part number for the Dart 111" WB than for the Valiant/Barracuda 106" WB for the equalizer cable. Hope this helps a little.
