Burntorange70
Was going to go with Lexan side glass and light weight inner door handles. Seen this at a car show and if you look down at the lower right you will see a hole in the lexan so you can open the door from the outside too and then delete the outer door handle as well.
Thinking of going this way unless it will not pass tech. Any one know?
Thanks for the help all.
