Will this PB Booster fit & work on a 65 Barracuda
hemi71x
Rancho Cordova, CA
I have a customer in Australia that is interested in this A body power brake assemblie that i have.
But i don't know what year and body style of A body that it came out of, as i purchased a estate sale of parts, and the seller didn't know what it came out of.
Will this fit and work on a 65 Barracuda?
I don't want to sell it to my client in Australia not knowing if it will, or won't.
Thank's in advance.
I know there are lots of A body gurus out there in For A Bodies Only.com land that i'm sure will know.
Jim V.
I've got the same booster/MC mocked up in my 65 GT 'vert so I could fabricate the brake lines. Booster Dewey out in OR rebuilt a spare same as pictured and I'll be using the rebuilt one in my 65 wagon with a 340. Should work just fine as long as his is a LHD - can't say for sure about the RHD versions.
Thank you.
His 65 Barracuda has been imported from here in the states, so it's a 'leftie".
I've used them but you have to modify the support struts (which I don't see in your photo). If you don't use them, the booster assy. will move around and eventually crack the firewall. Naturally, he'll need a different proportioning valve and lines to go with it. It's not a straight bolt-on unit. If he's keeping the drums on his car, you'll have to change the master cylinder too.
