on the wing window ( 70 dart 2 door hardtop) there is a little channel where the window slides in. on the window there is two small holes one up near the top and one down towards the bottom. there are little plastic type clips that go through the holes and slide into the the track in the quarter and hold the window in at that point.
so what is that plastic piece called and where can i get some
thanks in advance
thanks in advance
