wires??
leblanc
member 2883
Dieppe, New Brunswick, Can.
I am running a 79 360 in my 76 Dart Sport. What should I run for plug wires? The engine has about 300 HP, mainly stock, RPM intake, headers and a little more.
You shouldn't have any need for anything other than a set of stock replacment wires. You could use the better Belden line of wires that Napa sells and you should be just fine. You could also run the Accel wires or any other lower end performance wire with out ill effect.
