Wiring Harness ?
abodybill
48725 Michigan
Got a couple questioins are the wiring harness's.
I know that someone posted about getting the brass ends from the NAPA parts houses so I need the P/N for both the male/female ends.
If they are still available from the dealers?
Or if anybody knows where I can get the correct ones the brass with the little lock tabs on them I would like to know.
Thanks,
Thanks,
Which terminals are you asking about?
I'm looking for the brass female terminal with the locking tab on it.
I knew if anybody would answer it would come from you :mrgreen:
It is for a dash harness for the Mr.Norm's car and all fit perfect but 1 stink'n terminal the one for the heater blower motor the one on it is to small.
any help will be much appreciated!!
Thanks,
Try Standard part number ET708. You should be able to get standard through your local carquest or even possibly through OReily's.
