Need help from the group! Trying to get everything figured out for my Autometer gauge kit for my 73 Duster before removal to make everything go efficiently. What did you guys tap into for your 12v+ switch sourch for wires going to the gauge circuit board and what ground did you tap into as well? Below is what I have and have not figured out so far to tap into for gauge kit utilizing the existing factory wire setup. Hopefully this helps others too. Will update post as I get answers.
Dont Know
12v+ switch source ?
Grounding wire?
Left Turn Signal dash light ?
Right Turn Signal dash light ?
High beam indicator light?
What I know
Temp Sender -Violet
Oil Pressure Sender - Gray
Fuel Sender- Dark Blue
Emergency Brake Light/Low Brake - Black
Voltmeter- bypass ammeter series setup
Dash Gauge Lights- Orange
Tachometer- plugs into my MSD 6AL
Dont Know
Grounding wire?
What I know
Temp Sender -Violet
