[SOLD] Wisconsin 360 pistons
408 swinger
Iowa
New set of stock stroke 360 pistons. Taken out of bags to weigh. One pin out of bag to weigh. Dealing with a limited compression class, and, can't use. Pistons, pins, locks, and rings as a kit. Paid 400. Will take 350 shipped to your door. Thanks,FABO!
Yes, they are .030 over. With 65 cc chamber and .039 gasket figures to just over 10 to 1.
Part Type: Piston & Ring Set
Model: ProTru Street Forged Piston & Ring Set
Application: Chrysler 360
Piston Style: Flat Top
Cylinder Bore: 4.030"
Compression Distance: 1.665"
Crankshaft Stroke/Rod Length: 3.580" with 6.123 Connecting Rod (365ci)
Deck Height (Zero Deck): 9.578
Dome Volume: -5cc
Compression Ratio w/65cc Heads: 10.4
Compression Ratio w/68cc Heads: 10.1
Piston Material: Forged 4032 Aluminum
Valve Reliefs: Over-sized Symmetrical
Accumulator Groves: No
Forced Pin Oilers: No
Gas Ports: No
Skirt Coating: ArmorGlide™
Lock Removal Indents: Yes
Average Piston Weight:
Wrist Pin Style: Press-Fit or Floating
Wrist Pins Included: Yes
Wrist Pin Size: .984"
Pin Lock Included: CS24 Lock Rings
Ring Grove Sizes: 1/16", 1/16", 3/16"
Piston Rings Included: Yes
Manufacturer: Wiseco Performance Products
Manufacturer's Part Number: PTS527A3
I did some quick cal, I could be wrong but it looks like it's .022 below deck and with 72cc head around 9.3:1 cr?
Those specs are pretty much spot on. I came up with 10.37 to one with 65 cc head, .039 gasket, .005 below deck.
No, block is NOT for sale. Going with a dish piston to knock down compression.
