I didn't see any witches in the picture.
Don't expect posters to want to waste a great deal of time responding to threads written so poorly as to be unintelligible. Spellcheck is your friend! Google grammer girl for help with sentence construction and punctuation.
Volume knob is on driver side, fully counterclockwise should click into the power off position.
Odds are the outer ring behind volume knob would be tone control if it has one.
Power in wire is most likely an orange one, sometimes with, sometimes without some other colour tracer stripe.
Output to the speaker is usually, but not always, yellow, and because AM radios rarely if ever have a built in front to rear fader, there should only be one.
If by some quirk this one did have a built in fader, the outer ring behind the tuner control would be the probable control.
Black wire if you find one will almost always be a chassis (radio) ground.
