dart_runner
Member
so the dart i bought yesterday wont go into park is this a common issue and how do i fix it thanks
nick
nick
If it's a cable trans, the park cable may be bound up or broken. If it goes into park but won't stay there, the over-center spring is probably broken or missing. If the car is linkage shift, it might be out of adjustment or some of the linkage bushings could be worn out or missing. On rare occasions there could be an internal trans problem.
/6? It's probably a 904 tranny.
We need more info.
Most likely is the linkage is out of adjustment, worn, bent, or has a bad bushing. Before doing any work on it, make sure the wheels are chocked (or ideally, the car is up in the air on stands). If all the bushings and connections are good and tight, disconnect the shift linkage right at the first lever on the transmission. Push that lever all the way to the rear (that's Park). Check to verify that the driveshaft won't turn. Then put the shifter in the Park position. Adjust the linkage so the last rod will slide into the hole in the lever without having to force it. Move the shifter to 1st/low. Pull the link back off the lever and verify the trans in in low (the forward most position) There again the link should slip into the lever hole without having to move the linkage or forcing it in. Sometimes adding a washer to various linkage connections will help tighten things up if you have a lot of slop. Just make sure nothing binds and that the hairpins/cotter pins are installed and in good shape.its a 73 dart im not sure on transmission type its a slant 6 225 automatic
A '73 Dart does not have a Park cable. It uses the same linkage for all transmission positions, Once you get inside the transmission, the park linkage splits off with a rod that operates the parking pawl.The comments above are great, but need clarification. "Park" consists of two separate functions and linkages.
1. "Transmission gear selector", which is a series of levers in your car. This controls the transmission shifts thru the "valve body". The factory or Haynes manual should explain how to adjust the linkage, since that is a regular maintenance item. Similar even in new cars. If not adjusted correct, the "neutral safety" switch will be open which disables the starter relay.
2. The other is the "park sprag lock" which is a cable going to the rear of the transmission. This is a cable in all Dart years. This sets a pawl in a tooth on the output shaft and locks the wheels. In newer Chryslers this is done in #1 via an internal linkage in the tranny. This one is most important for safety since not everyone (ex. my wife) thinks to set the "parking brake" (or "E-brake"). My friend's truck was recently messed up by his wife not setting the brake and leaving in "D".
cudamark,A '73 Dart does not have a Park cable. It uses the same linkage for all transmission positions, Once you get inside the transmission, the park linkage splits off with a rod that operates the parking pawl.
