A couple of my observations;
>When the coil ballast resistor is cold, a decent coil can run 12 or more volts for long periods of time..
>A Mopar Dual ballast Ecu will run on battery voltage for a while no problem
Since it seems to be rpm related, and NOT carb related, I offer two possibilites;
1) make sure the reluctor gap is more than .008 and less than .020, and remains so on every vane, even with the shaft side-loaded.
2) make sure the pick-up polarity is Not reversed. It is possible to set the Idle-timing with a reversed polarity, but as soon as you start to rev it, the ECU get confused and randomly does strange things, like dropping sparks, and, get this ....... it won't rev up. lol
