My 318 occasionally will not start. I don't even get a click when I turn the key which I thought I might get if it were a starter problem. Instead it is silent, there is power as gauges move and lights come on with the turn of the key. The frustrating part is that it has happens once every 5 -10 times I drive the car. The battery connections are tight. I would say it happens more often when hot. But it has happened when cold too.
It will start if I pop the clutch. Does that mean it is the starter alone or should I be looking elsewhere?
