Thanks but that is telescopic not a fixed mast. The 72 A bodies had a fixed mast antennaLook on e bay that’s where I got the whole set up and cable
Or classic Industries
Thank YouView attachment 1716302388
View attachment 1716302393the place is called strip classics on e bay motors this is a one piece antenna
Your welcome it took me 2weeks to find that place but worth it in the endThank You
thank youOriginally AM-radio-equipped cars would've had a 76.5" telescoping mast while FM had a fixed 31" mast to maximize FM reception. Both are shown in the 1972 parts book.
You only need to replace the mast; the base is the same between the two. It was common for dealers to replace telescoping masts damaged by garage doors, car washes, etc. with the stronger solid FM mast.
