WTB: 64-65 273 4 barrel intake
I believe my only option is the 64-65 Commando intake? If anyone knows different enlighten me please.
Thanks
...for the early 273 heads, yes, but, if you want spend a little money, a later one, or small-port aftermarket aluminum intake can be machined to fit and work fine.
Not sure on what you want to spend but Offenhauser has made one since back in the day and still makes it. It has been awhile but last I looked at Summit online they listed it as able to be ordered.
ow much you willing to spend i now a guy that is selling a273 motor i might be able to talk him outa his thats cast i bet shippn pro 30 -35 pm me all i can do is get turned down
I have an original 273 hipo cast 4 barrel intake. I have one interested buyer but if it falls through you are next in line. It is bead blasted and primed so choose your color. 100 bucks plus the ride. Pm me if interested.
I have a 4 barrel intake for a 273 for sale it takes a standard afb carb I'll take 50 bucks for it. they will fit on all 273s. I also have a solid lifter cam and lifters for the same engine also the push rods. I have a rebuildable 273 block I would like to sell. As a matter of fact, I have the whole engine including pistons. the crank is kaput due to a spun rod. the pistons are usable but number one rod is no good for the same reason. get in touch with me and we can discuss it.
