WTB: '72,'73 340 pistons
thanks for the link there is a set of 8 nos ones on ebay for $80 as well. I just figured I would see what is out there in the used department first and maybe save some more coin.
You're looking for standard bore? I have a new set of cast .040 over pistons, too.
Do you still need that taillight? I didn't hear back from you when I asked about needing just the lens or the whole unit.
O sorry I thought I sent a reply on the lens, I just need the lens and yes I am still interested in it. I am looking for standard bore on the pistons.
I have a good used set of standard bore 340 pistons from a 1973 cast crank motor..... they are the original 8.5:1 pistons........Give me your e-mail address and I will send you a pic....Paul
I am doing a trick little something that involves a 360 block : )
by the time you deck the pistons and then cut the skirts so the crank does not hit them...
you could of bought a set of KB107s....JMO..
if you want cheap...seal power 405...
I have an NOS set. I'd like $80 for the set. I think that's what I paid for them several years back.
