swinger340
Has anyone tried stock mopar heads on a LA stroker motor? If so what kind of power did it produce?
I had X-Heads on my 418 with stock HP exhaust manifolds. Engine dyno peak power of 393 HP @ 4900 RPM and 472 Torque @ 3700 RPM. As stated above; it just couldn't pump any more air and ran out of breath around 5500 RPM. Heads had some bowl work and mildly ported.
Best of 12.96 with 3:55 and 2500 PMC converter on MT Drag Radials.
What did the heads flow...Got some numbers ???I built this one last year with 596 heads. I make pretty good power.
http://www.forabodiesonly.com/mopar/showthread.php?t=189991
I know this is an old thread but I have seen this build referenced several times in other threads and the link doesn't work. Could MRL or somebody chime in and tell me where I could read this thread?I built this one last year with 596 heads. I make pretty good power.
Guy went out of business years ago. Was known for "grossly" exaggerating dyno numbers. His engines typically made about 150 HP less than "advertised" backed up by real world testing.I know this is an old thread but I have seen this build referenced several times in other threads and the link doesn't work. Could MRL or somebody chime in and tell me where I could read this thread?
Thanks.
@MOPAROFFICIALIs 1wild&crazyguy on here still on a different name?
my current shortblock he originally built. Got it very lightly used( one summer while guy waitEd on his hemi power train) from a guy on the other side of the stateGuy went out of business years ago. Was known for "grossly" exaggerating dyno numbers. His engines typically made about 150 HP less than "advertised" backed up by real world testing.
Wow, amazing.my current shortblock he originally built. Got it very lightly used( one summer while guy waitEd on his hemi power train) from a guy on the other side of the state
the shop I use( excellent reputation) had to fix pretty much everything he touched on it.
Terrible bores, no fixture used, was tubed for roller cam, all the lifter bores on that side we’re wallowed out at the bottom, had to bush all the bores, on and on.
I ported a set of 1971 915 j heads. Spent months on them. They went from 160cc to 186cc... you don't get there overnite , that's for sure. At first a few went 270..others went 257-260's cfm...so I pulled the trigger on a flow bench.. and began working them till they all flowed withen 5cfm of each other.Has anyone tried stock mopar heads on a LA stroker motor? If so what kind of power did it produce?
I'm curious about something. Have you ever weighed a bare casting both before and after porting?I ported a set of 1971 915 j heads. Spent months on them. They went from 160cc to 186cc... you don't get there overnite , that's for sure. At first a few went 270..others went 257-260's cfm...so I pulled the trigger on a flow bench.. and began working them till they all flowed withen 5cfm of each other.
No tesla, turbo this or tht ,Benz beamer super cars that the rich 'a wads' drive around here can touch it. Street or freeway... I will leave you. Never got it to hook all that great.lol it would break tires going 65 or so if I dumped it.
It flowed better numbers than a rhs head at the time, talking 249cfm by .400 lift... 270scfm at .500...hell the damn .300 numbers are in the 200's ...like 204cfm.
Quench tops and .030 p/h clearance.
Paper thin push pinches.
It's not whether or not you can make 500+hp with factory iron..its whether or not you know how and have the time.lol
After porting, one pc bronze guides, hard seats both intake/exh, spring seats cut and .045 ish milled... they were maybe 2 lbs lighter. I don't know for sure but I can weigh them agaisnt some bone stock 70 castings I have. You can definitely feel the difference if you pick one up, but they're still iron. If they were ever to be that light 'like aluminum' they probably wouldn't last long once the engine warmed up LOL.I'm curious about something. Have you ever weighed a bare casting both before and after porting?
