Yet another timing question
keelhaul21
Member
Raleigh, NC
Here's my question. What should my init. timing be, or a good starting point, for a 318 4bbl with a stock 340 grind cam? The motor also has a MP ele distrib. with an onrage box.
Id mod your distributor(the stock timing curve is not performance oriented) and start around 32 degrees at full advance (3200 rpm +/-)
