1974PlymouthDuster
On the 74 Duster with 318, I have been steadily increasing my idle voltage troubleshooting steps...
#1 - Sanded and filed down fender holes and Voltage Regulator holes.
#2 - Dielectric grease on terminals of Voltage Regulator
#3 - Switched between three voltage regulators I have kept on hand
#4 - Ran #4/6 gauge wire from alternator stud to hot terminal of starter relay
All these resolutions (From reading post after post about this) left me with the same 14-15v idle voltage.
Unplugging the VR (any of the 3 VRs I have) seems to set idle voltage right at 14v
**one of the VR's leaves me with 15v idle voltage, and 16v revved voltage (pulled that one out quick)
Revving the engine above 1,000 rpm leaves me with a nice steady 14v too - This resolves all my issues with all VR's I have tried.
I have a squareback alternator, but I do not know what the actual/advertised output is. I do recall recently having this and an alternate alternator tested at Autozone, but I dont really trust these results.
Is this the stage where I just pony up for a upgraded alternator, or even just go 1-wire? I have also looked for a upgrade rebuild kit, but these seem to be out of stock everywhere I have looked.
Let me know if there is any other troubleshooting I can attempt? Thanks guys - FABO has been such a resource for our Duster and Valiant !! (see Members Restoration for my name)
-Ryan
-Ryan
