41husk Well-Known Member Joined Oct 4, 2011 Messages 909 Reaction score 14 Location Southern Illinois Oct 31, 2011 #1 I have a 71 Duster that had a 3spd, I am swapping a 4spd and still have the 3spd Zbar installed will that work with my 4spd. Thanks!
mopardads67 Well-Known Member Joined Mar 24, 2009 Messages 502 Reaction score 8 Location MD Oct 31, 2011 #2 I don't know if I can be much help because I'm still longing for my first A body 4 speed,but why would a 3spd trans or a 4 spd trans even need a different Z bar all it is,is a lincage to transfer verticle to horizontal motion right??
41husk Well-Known Member Joined Oct 4, 2011 Messages 909 Reaction score 14 Location Southern Illinois Oct 31, 2011 #3 yes, but whant to make sure it is not different. I would rather not remove the one already installed.
Mikes270dart Well-Known Member Joined Sep 26, 2010 Messages 365 Reaction score 126 Location Toronto Oct 31, 2011 #4 I had a 72 dart 318 3 spd and changed it to a 340 4 spd, same z bar used.
41husk Well-Known Member Joined Oct 4, 2011 Messages 909 Reaction score 14 Location Southern Illinois Oct 31, 2011 #5 Thank's !!!
C crackedback FABO Gold Member FABO Gold Member Joined Aug 7, 2005 Messages 19,183 Reaction score 5,928 Location 92201 Oct 31, 2011 #6 As long as you aren't changing engine/bellhousing, the z bar should work fine.
41husk Well-Known Member Joined Oct 4, 2011 Messages 909 Reaction score 14 Location Southern Illinois Oct 31, 2011 #7 I am going with a 340 vs 318 engine measurements should be the same?
