Zee bar Qs
moparmat2000
Grand Tetons
i am putting an A-833 OD tranny in my 67 cuda, i am using the OD V8 bellhousing. casting is from 1977 so probably out of a volare or aspen F body.
i am looking at clutch Zee bar rebuild kits. one kit is for 67 to 71 A body, the other kit is 72 thru 74 A body.
everything looks the same in both of the kits except for the pivot ball and bracket that bolts to the bell housing.
which kit will work for me. i am buying the kit to rebuild the Zee bar, and also because i need the bellhousing side pivot bracket as i dont have this part.
thanks in advance
Matt
