MidnightSwinger
New upper bearing, and welded Borgeson style joint. This column has the courtesy light.
The light and lower bearing need to be reinstalled. I had the column torn apart to paint, and then I had to move, so I assembled it mostly, so I wouldn’t lose anything.
I do have the key. Includes extra manual steering shaft if you prefer to switch back to the rag joint.
$150 plus shipping from 95695 Woodland CA
