[SOLD] 1970 DUSTER 340 4 SPEED RESTORED
couper 340
maryland
1970 Plymouth Duster 340 4 speed bucket seats 8 3/4 rear 3.55 gears This car was restored in 2013 the only metal parts that were replace was right rear lower qt panel and extensions. spare tire well all other metal is original . New seat cover and foam , carpet, head liner rebuilt .020 over 340 with j heads not # machining but correct to car and date code . small cam 441 lift 218/ 228 dur @50 ,rebuilt 4 speed HURST shifter and also 3 speed training oem .rebuild 8 3/4 posi 489 case with 3.55 gears and also a 741 case 323 posi oem to car rally wheels and dash with am/ fm thumb wheel radio BFG Tires 245 60-14 rear oem 4 piston disc brakes front, 7 blade fan clutch , all suspension rebuilt . add a shark tooth grill and 71 strip kit .Pypes x pipe exhaust car was a Texas car B5 blue was no build sheet with car. New AMD Tinted glass 1,000 mile on car since restored not a show car but very nice car . ASKING $ 30,000
here are some of the Resto back in 2011 to 2013 they are not the best pictures from phone.
Is that the orginal color or was it rootbeer metallic?
I sold a 1970 340 4spd to a member here who said it was gonna be restored... but I wonder if he just used it as a donor...which would be lying.
Who restored the insterment cluster
instrument specialties did the speedo head only i got new boards at the Mopar Nationals and a guy near my Rechromed it for me but he close since wood decals from detroit muscle and i put it together.
This car was born b5 and still is came from Texas and a guy in ohio bought it and never did anything with it because he found a cuda the wanted more . when i got the car it had been painted silver way back when.
Do you have any engine compartment pics along with the fender tag, and trunk pictures? Thanks!
was a b5 bench car i changed to buckets and black now and 3 speed a230 and 741 3.23 they come with the car if some one wants it .
It was originally sold new in Texas ?
i would think so it still had the texas tags on the car and last sticker was 1990 and the guy i got it from had just re title it to sell it. he bought it and never touch it the engine was missing when he bought it . again the only metal that was replace was right lower qt and spair tire tub and i put trunk extensions .
Trying not to trade as i am getting to old to do another car and 1/2 way in to a track car i was building and have not touch it in 8 month.
Ok
I think I’ve done that but since I’m new here (and an old geezer) I may have messed something up. I’ll try again.
Thanks!
Ok then if you go to the top of any page, click on the envelope. You will see all of your pm's (private messages) that you've sent and received.
