360 Main Bearing difference
lemondana
BlackDart
Southeast NE
I've been looking for a set of .020 under main bearings for a 1973 360. A couple places specified 71-73, and 74 up. On Rock Auto, the part numbers are different. Anyone know what the deal is? I looked in the 1973 Parts Manual and they listed up to 1-15-73, and after 1-15-73 with different part numbers. The after 1-15-73 listed as Heavy Duty. Anyone???
The center bearing main cap and block is machined different in the block.
All the other bearings are still the same it's just the center thrust bearing has a bigger flange. Now I believe you can use a small flange bearing in the later blocks. If you want to.
