Bottom timing gear for crank how loose
Gabriel Larson
Oregon
Putting together a 1969 383 and was about to do the timing chain when I noticed the crank timing gear slides right onto the crank. No tapping required. Should it be tighter fit? I know the damper will probably tighten it up but still thought it would need a hammer to put it in place.
Does it have any rotational slop? If not, run it.
A little bit almost like either the woodruff key is to small or the slot in the gear is to big I’ll measure it when I get home later. It’s probably no more than 2-3 thousands of slop. Just enough to wiggle a tiny bit
Doesn't the vibration damper wedge the gear into place between it and the crank?
Also on a 1.5" dia circle you have to move the gear 0.013" to get 1 deg of rotation.
0.003" is about 0.229 deg
In my book that is negligible
Here’s the amount of play it has
So I hit the woodruff couple times with a hammer on the front end and now the play is gone so I guess problem solved
