[FOR SALE] "Fixed" 440 TQ Intake
Killer6
PA
For those of You familiar w/these, You'll see what's been fixed, nice sleeper intake. The "iron butterfly" was run w/a square to spread-bore adapter & a NOS plate. $150, can quote shipping if desired, UPS ground
Have you magged it? Those are REAL prone to cracks between the secondary bores, and also in the EGR valve passageway.
how much of a difference do you think this mod made?
If You know that intake, You know what #3 looks like, this will need a custom a/c support to use it.
I can tell You it pushed a '73 Satellite that scaled 4050# at Quaker City empty w 1/2 tank + a 300# driver to 100mph with a 280/.470 Purple Shaft. Running pig-rich (unexpected when He added an Extreme K&N top), so not near dialed in, & certainly not a hot set-up. 750 3310 Holley, 9.8:1.
Intake was on that car from '94 'til 4yrs. ago when it was pulled for a Perf RPM. No comparo because of a bunch of big changes went along w/that.
Look into 1 & 3, paint came off before brazing block-offs in crossover. The plenum divider mod was to ensure the NOS plate discharge did not deflect & disrupt carb flow once installed.
