I need to barrow a 67 up console tach mounting base
Dana67Dart
The parts you don't add don't cause you no trouble
Northern Colorado
I do reverse engineering of parts the aftermarket does not.
I would like to RE the mounting base for the A Body console tach.
67 up to (????)
I have never had one in my hands so I don't know what parts would be needed to make a proper mount
I suspect the plastic, the metal and perhaps the hollow bolt and nut (unless that part is part of the tach.)
I will pay shipping both ways and would need it for maybe 2 to 3 weeks.
My intent is to make 3D printed Stainless Steel parts as close to the original as possible.
Alternately detailed photos and key dimensions might work.
I have worked on several parts for @j_anderson in this manner with awesome results!
Pm me if you would like to participate.
I believe there are two slightly different mounts, one for 68 and earlier and one for 69 and up. Reason I suspect this is because of the different top plates on the console itself. 68 and earlier have a machined groove running the length of the console. The pedestal, mount or adapter whatever its called has two small nubs on the bottom. I believe these sit in the recessed groove. The 69 and up console has a flat surface and doesn't require the "nubs". Will try and post pictures later today.
Took a couple of quick pics before I forget. Can post better later if needed
That's great info.
Thanks.
Super easy to make one CAD file and have them as a feature that can be turned on and off
Anyone know what years this particular mount covers 67 to 69 for sure but 70 thru ???
