NoCo alignment shop for our cars
dddDuster
Eaton, CO
Any have a recommendation for an alignment shop for our cars? 1970 Duster, I’m finishing up replacing pretty much everything up front and would like to get her lined up!
A stand alone shop would be the best.
There is one in Loveland on 34 by 287
Bring the schoch(sp?) Spec chart
The alignment is not too sophisticated that a semi talented shop should be able to figure it out.
Bring the torque specs from the factory service manual
Thanks, looks like Scott’s Loveland auto is right there and T&T OK tire is around the corner. I’ll check em out!
Scotts is the one I was thinking of.
I have not used them but I did talk to them once and they seemed knowledgeable
I imagine there are shops out by you.
What are you driving, post a photo.
There are 2 car shows this coming weekend,
Fort Collins dodge Mopar only on Saturday.
Izzy's body shop on Sunday
I'll be at both, look for the red surf board and blue 67 dart convert.
If you’re running radial tires, use this…
Thanks for all, I’m hoping to make the FoCo show Saturday, will see if we are done with babysitting for the week! I am checking with Kennedy Automotive out here today, they are good guys, just don’t know if they do alignments on old cars. Here’s a pic of my car, nothing special, definite work in progress!
Geib's Alignment in Hygiene, CO, was where I went to when I lived in Longmont. Came very recommended by a good friend as knowing how todo a bodies right​
I missed touching back on this. I had Jay’s Automotive here in Eaton do this, good guys and it worked out great! Between replacing all the bushings, adding a front sway bar and the alignment, the car handles great now, thanks for all the suggestions!
