[FOR SALE] 1973 Dodge Dart Sport
subrambc
Member
Boulder City Nv
Rating - 0%
0   0   0
A 73 340 Dodge Dart Sport.
California Car Vin#LM29H3B169296
Engine: Mopar Performance new 340 block Machined and built to 408 cu.in.
Internals: Eagle Crankshaft,JMS Rods internally balanced. Pistions:Ross High Performance.
Camshaft: Competition Cams.
Rocker Arms: Mopar Performance.
Cylinder Heads: 1972 - 360 “J” , JMS Valve Springs 16 valves , seats , machine work and gasket match.
Valve Covers,Intake Manifold, 3 holley carbs, linkage and fuel lines, Ignition and Air Cleaner all New Mopar Performance parts.
Transmission, Converter and Flex Plate:
TCI Automotive - Street Fighter 727 Torque Flight.
Heavy Duty Electric Fan and Trans Cooler.
Differential: Anaheim Gear Dana 60
4:10 posi.
Axles: Yukon
Brake system: Completely New
Exhaust System : Custom Built Flowmaster with side exit Challenger style tips.
K Frame: Barnett performance suspension.
Steering Box: Flaming River 16:1 ratio
Drive line :New OE
Cooling : High Flow water pump
3 row copper brass Radiator.
Suspension: Firm Feel Control Arms,with urethane components,Strut Rods,Tie Rods, Drag Link,Pitman Arm and Idler Arm.
Rear Leaf Springs :Mopar Performance.
Other Highlights:
Amsoil Fluids, Battery in Trunk .
OE Direct Connection Tachometer.
Car was built in 2011-2012
and then Tied up in California Probate
for almost 10 years
i acquired the Car in 2021
and was contracted to make it run and drive after being in storage.
It has never been raced only driven on the street.
We began some minor rust repair this last winter and I realized body and paint is better left to a professional.
The interior needs a refresh also.
instrument cluster and dash wiring need to be reconditioned.
I did install more modern shoulder seat belts.
The car runs like a seven Jewel Watch .
Im asking
$18,500
PM for more info
Transportation Available
The Mechanical and suspension are done.
finish the Body and Paint and do what you will with the interior.
* The Car is an original 340 California car “Black on Black” no ac
* The Car is in currently in Southern Nevada
