[SOLD] 416" Molnar Technologies Complete Balanced Rotating Assembly for 340 Block - New
PROSTOCKTOM
West Central Indiana
Molnar 4.000" Stroke 4340 Forged Steel Crank with 2.125" Rod Pins for 340 Main Block
Molnar 6.123" 4340 H-Beam .984" Wrist Pins, Molnar Proprietary ARP2000 Rod Bolts
ICON Premium Series/ KTD .030" over pistons with Premium Rings. Your choice of dished, flat top, domed, to suit the compression ratio you want to accomplish.
Most pistons are also available in the following bore sizes. 4.00", (4.020" only available for domed), 4.030", 4.040", 4.060", 4.070", 4.080"
King CR805XPN Rod Bearings
King MB558XPC Coated Main Bearings
Please note: King now only offers 340 main bearings in the coated version. These cost double what the standard XP's did, so it has increased the kit price for the 340 engine only.
Balancing for Assembly - Molnar would balance all the components in house (Rods, Pistons, Crank). Internal Balanced (Neutral)
The total cost including all parts, balancing, and shipping is $3364.75
Please note that $211 of this price is the balancing cost and $221 is shipping cost for the 3 boxes it takes to send a complete rotating assembly.
Current lead time is 3-4 weeks before you would have it.
Just let me know if I can help you with a complete assembly or just a part of one.
I now only accept payment by PayPal Friends and Family, Bank Check, or Personal Check with time allowed for check clearance
Thanks for looking,
Tom
So I can only get a dime piston in a 4.02 diameter? I have econo W2s and I want 12.5 to 13.1 comp.
Hello,
Tried sending you a PM, but your box is full.
I need to delete this ad since new sizes are now available in domed pistons. The following are now available.
4.00" STD / .020" / .030" / .040" / .060" / .070" / .080", so a .030" over 340 would use a 4.070" piston
.085” S/Dome -5cc
505 Gram Piston Weight , 118 Gram Pin Weight Valve Reliefs Intake .280”-2.250”, Exhaust .274”-1.820”
