Brake Valve
64_Barracuda
Virginia Beach VA
Virginia Beach, VA USA
Anyone have any part numbers or what type of brake proportioning valve and location for disk brakes with dual reservoir master cylinder? Building a 65 Signet, the valve was up on the fender well when I got it, moved it down on the rail but it looks kind of tight down there.
It's cramped because your using a horizontal type proportioning valve from a late 70's early 80's car. These were typically mounted up higher, closer to the master than your early distribution block was. While you can raise this one up a 73-76 Dart Valiant disk brake valve bolts right in and provides more clearance due to it's vertical design.
The dual reservoir only matters if you are using the imbalance switch on the "combination valve", and 65's don't have a dash lamp for that. Otherwise, you need just a proportioning valve in-line w/ the rear tubing. An adjustable one is best and cheapest (<$30 ebay). I mounted mine up high beside the MC.
The combo valve does have one other feature - a hold-off valve for the fronts, but I don't know that helps much. I don't know if yours has that since it is not familiar looking. The 70's Dart ones had square corners, not a rounded casting.
